Search bar becomes totally white which cause not able to read what we are typing
hi, Whenever i open firefox browser, and go to search bar to type the searchbar goes totally white. Tried uninstalling, clearing cache but nothing helped
Hello,
I am going to create a bug report regarding your issue, and I would also appreciate some more information for it.
First, please try changing your address bar position from top to bottom (Settings -> Customize). Does it affect the issue?
Second, please tell what theme is set in your Firefox (Settings -> Customize). Dark or "Follow device theme"? What is your device theme?
Hi, I tried setting searchbar at bottom, saved the setting and restarted broweser but issue persist. Themes I have used device based.But I tried already light and dark theme so no effect on that Thanks, Rajiv
Hello,
Thank you for checking. You mentioned the light theme – does choosing this option in Settings change your browser theme or at least something in the UI? And when your device theme is light, does Firefox follow this theme?
